How to smooth peeled aluminum
I dropped my MacBook and there is now a sharp piece on the corner. What tool would you use to “sand” it down so it doesn’t rip up my palms?
Thanks!
Это хороший вопрос?
Thanks!
Это хороший вопрос?
Hi Marc,
I would try a fingernail file that is not very course. They come n many different styles and flexibility. Start very fine and work up until you find the one that removes these sharp edges to your liking. Hope this helps.
Был ли этот ответ полезен?
Ouch that looks bad!
Cutting off or banging down the flap is a start but that still leaves a hole in the case and that corner is still rough. So I can see two options here:
If you patch use a small hand grinder Dremel Tool to smooth out the area while it won’t look the same it should be good enough and you’ll prevent anything entering. Epoxy won’t hold up but thats an option.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 134
