The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
No Power Issue SNES
My SNES has stopped working, measuring the output of the power cord, the max I got was 1 volt, does this mean it is the power cables fault? This all started when the console fell, so I have checked the insides of the console and the charger, the console looked completely fine on the inside. I tried to measure from the chargers transformer itself but I don’t know which parts to put my prongs on. Most likely I think it’s the cable, I don’t think it’s the power connector itself, I have measured around the same voltage on the console itself that I did on the power cable. On Continuity mode, I put one prong on one of the power prongs, one on the other side of the cable, no beeping.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
We have found that this issue can be caused by using an underpowered AC adapter or power source. The problem can be resolved by using a licensed AC adapter. You can purchase one from the Nintendo Store. If a licensed AC adapter is unavailable, you can try using a different AC adapter that is rated as 5V/1A. Now i am sharing this helpfull answer No Power Issue SNES- apkbik
thanks
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Connor Steffenhagen будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 618
