Смартфон Samsung Galaxy Core Prime Duos на базе Android — это модификация линейки Samsung Galaxy Core Prime. Номер модели: SM-G360H/DS (SM-G360H/Dual-Sim). Выпущен в ноябре 2014 года.
How to repair ghost touch
the phone screen touches by its self
Это хороший вопрос?
Счет 5
3 Комментариев
This phone is not for working on touch
из
@chiranjitdas
See the suggestions shown below in the Most Helpful Answer
из
My mobile phone screen is damage and he doesn't work and keys can't work
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
So there’s actually a few things that can be causing this issue with your device.
  • The primary suspect could be an issue with the phone’s software. Make sure that the device is up to date. If anything else a forced reset of the device can help the issue.
  • The second suspect issue could be overheating or extreme cold. Definitely see if the issue continues if the phone is in a neutral environment.
  • If your phone is using a screen protector, definitely try removing the protector and see if the issue continues.
If all else fails, then it may be a defect in the screen that could be causing the issue. This would mean that the a replacement screen would be needed.
Был ли этот ответ полезен?
Счет 1
Makee sure monkey testing suit is turned off
Счет 0
Добавьте свой ответ
Tonny Mike буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 19
За все время: 1,021
