iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467вопросов Показать все
iMac 27 late 2009: Blank screen after 5 minutes
I have replaced the logic board on my imac (previous question), it seems to work but after ca 5 minutes the screen goes black. When I restart, the same problem after 2-3 minutes. What could be the reason?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi Tony,
Seems like there’s some sort of incompatibility or fault.
Judging by the fact you did a logic board swap it seems you have the tools for these imac repairs.
When this issue occurs, can you shine a flashlight on it to see if theres any image. If so then the backlight connector is not seated properly
If not, try a power cycle (If u don’t know how to do that either i or someone else can explain)
As a last resort try and swap the boards out again and see if the issue continues.
If so then something is clearly damaged hardware-wise and needs replacement. My guess is the display cable is somehow being interfered with.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
thanks for the hints; I will try them out.
I also wonder if the problem can be caused by the graphic card?
из
I agree with @np_f1_2021 direction you likely have a backlight issue, press the flashlight against the display at a sharp angle if you see the faint image of your desktop and its icons you've isolated this issue to the backlight logic. You could have a bad cap on the LED driver board which I've seen a few times.
из
Добавьте свой ответ
Tony будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 54
