A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
123вопросов Показать все
CTO iMac 27 5k 2019 with 2TB Apple SSD. Does this include a SATA cable
It would be an iMac 27 5k 2019 purchased in a CTO configuration. It comes pre-ordered with a 2TB Blade SSD from Apple and therefore does not include an HDD (Fusion drive).
My question would be if I buy a SATA SSD installation kit. will my HDD Data and Power Cable be included in my iMac? If not, what cable can I replace?
( There would be a cable detailed on page 88 of the Repair Guide PDF. ***``Service Manual - iMac 5K 27-in (2019).pdf )
The end result would be to have one Blade SSD and one SATA SSD in my iMac.
Thanks for everyone's help.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Apple does not install the SATA / Power cable 923-00664 when you get a blade SSD model you’ll need to buy it if you are adding a SATA drive (HDD or SSD).
Here’s the location of the connections, the Orange marked is the data and the Red marked is the power
Был ли этот ответ полезен?
Оценка 2
4 Комментариев:
Thanks for the quick reply Danj.
Then the brain was confirmed.
Where can I find this SATA / Power cable 923-00664 cable here on iFixit?
из
Sorry, iFixit doesn't offer this cable here's one source iMac 27" Retina 5K Hard Drive Combo Cable (L15/17/19), Apple P/N 923-00664
из
Thanks for the help. That's how I'm going to proceed. :)
из
@amp_hw_rep - Don't forget to accept the answer - Thanks!
из
Добавьте свой ответ
Peter будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 28
За всё время: 337
