The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
202вопросов Показать все
Power Supply 2009-2012 all same 980W?
Hi everyone,
I need replace power supply in Mac Pro 2012, can I use one from 2009 ?
I mean are all power supplies for 2009-2012 same 980W or is there any difference what should I watch out for (cables, connectors etc…)?
Thanks a lot.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
The power supply from a 2009 Mac Pro should be compatible with your 2012 Mac Pro. That is assuming you’re using the A1289 model.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Yes it's for A1289 model (2012) so as long as I will have PSU from A1289 it will be OK ?
из
@roboscrap That is correct. I found the compatibility information from here. https://www.macpartsonline.com/661-5449-...
из
Thanks a lot mate, appreciate that.
из
@roboscrap Always a pleasure to help out!
из
Добавьте свой ответ
Rob будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 134
