Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
Display connector - where can I get?
So basically a few months ago I spilled liquid on my M1 Max Macbook and lost my display.
I took it to a local Mac specialist and he confirmed the logic board survived the spillage but either I need a new display or connector.
I can find a whole display on eBay no problem but I wanna find out if I can get a separate connector and see if that works. Any idea where I can get hold of one?
Это хороший вопрос?
Счет 1
4 Комментариев:
You'll need to offer us some idea on which connector you think is damaged.
Frankly, the full display assembly carries everything and only the logic board connectors might be an issue but your show stated the logic board survived so I just can't figure out what you are looking for,
из
Hi
You haven’t told us what connector you need but not to worry
Chances are you will find it on eBay , Amazon or AliExpress as they have just about everything under the sun
Hopefully this answers your question
из
@danj Ah I see, sorry I'm just going by what the repair guy told me. He connected it to an external monitor and was getting a display and he said I may need a new entire display or just a new connector so I wasn't sure if it was possible just to change the connector to see if that works. Not entirely sure of the ins and outs of it if I'm honest
из
@hellomacos Not entirely sure as I'm just going by what the repair guy said to me. It's getting a display from an external monitor and he said I may need a new display case or just the connector.
из
Добавить комментарий
2 Ответов
You'll have to give us some suggestions on which connector you believe is harmed.
To be perfectly honest, the full showcase gathering conveys everything, and just the rationale board connectors may be an issue however your show expressed the rationale board made due so I can't sort out the thing you are searching for,
Был ли этот ответ полезен?
Счет 0
@hankscorpio - Time to find another shop that specialized in Mac’s and ask a few questions pointing to what the issue is. Reference this MacBook Pro 16" 2019 Teardown so you have some idea before you go.
Счет 0
Добавьте свой ответ
Hank Scorpio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 543
