I try to update to the new W10 update but it freezes at 42 or 48%
I try to update to the new W10 update but it freezes at 42 or 48%, so I restart it and it goes slower when I have to do that.
Это хороший вопрос?
Это хороший вопрос?
If you have the same issue I did, I got lucky with a solution after some Google searching. For some reason, completely deleting the drivers of the display adapter for the amd FirePro allowed me to get beyond the first Windows 10 update/install (1507). With each feature update to 20h2 and eventually 22h2 I had to keep deleting it. The 22h2 update was a little more direct after I did an update instead from Microsoft that allowed me to update with an installer instead of Windows update. During that I kept device manage up so I could keep deleting the amd drivers for that display adapter as they kept installing.
After getting 22h2 installed I let Dell command update to the most recent amd drivers it has for that display adapter, think the drivers were from Dec of 2022. Good luck!
Был ли этот ответ полезен?
I would first back up your main Hard Drive/SSD. Then download the update assistant from here. Go through and select the latest Windows update available and install it.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 182
4 Комментариев
What version of Windows 10 are you trying to update to? Do you have your C drive backed up?
из Andrew S
v20H2 and no I don't.
из NR26
How long have you waited before you do a hard shut down?
из Duck
@areeve Maybe 2 hours and why should that matter?
из NR26
