How can I remove wifi ribbon adhesive from logic board?
I removed the wifi ribbon cable from my 2nd gen ipod touch and it left some adhesive behind, how can i clean the logic board of the adhesive?
Это хороший вопрос?
Это хороший вопрос?
You can use some isopropyl alcohol. Use the highest percentage available to you. I would not use the rubbing alcohol, it does have plenty of other stuff in it. Talk to your local pharmacist and see if you can get a 90%. Use a soft toothbrush and carefully scrub the area. Make sure you do not knock of any of the components ;-)
Был ли этот ответ полезен?
Thanks,
I will give that a try.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 383
