Wire from airport antenna broke off from connector
I'm replacing the screen on a G4 powerbook. While disassembling the unit to remove the display I inadvertantly broke the airport antenna cable right at the connector when I tried to disconnect it, consequently the connector is now rendered useless.
My question/s is/are: Can I use a small butt connector to reconnect the airport antenna cable to the airport card cable or do I need to use the exact same type of brass connector?
If I do indeed have to use the same connector, where might I find one?
An answer to one and/or both of these questions would be most appreciated.
TIA....Jeff
Это хороший вопрос?
