Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494вопросов Показать все
Does a A1502 topcase+trackpad from 2015 fit into a A1502 mid 2014?
So I have a Apple MacBook Pro Retina A1502 from mid 2014.
Some of the keys started to fail so after going through a troubleshooting I've decided to change the keyboard. After a a few hours of work all seemed to work fine again. A week after the trackpad failed so I tried to change flex cable cause it looked bent to me but no success. Additionally a few days later some of the keys started to fail again so I've decided to change the whole topcase+trackpad. I've found a good deal on a A1502 from 2015. Does anybody know if it will fit mine?
Thank you for your help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Nope, unfortunately the 2015 topcase is not compatible with the A1502 of previous years/series. Trackpad is different and cannot be swapped either.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Roger Eivissa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 108
