Repair and disassembly guides and support for dish washing appliances.
707вопросов Показать все
Bosch dishwasher will turn on but cannot complete cycle
I have a Bosch dishwasher that will turn on and start running for a few minutes but never for the full cycle. It displays "Fault E05" on the screen. I have tried turning it on and off as well as disconnecting it from the circut breaker and waiting for a few minutes before starting it on again. Any suggestions would be appreciated!
Это хороший вопрос?
Оценка 0
5 Комментариев
@danj -- Do you think this is a part error code or simply something wrong with the software?
из
@teardowns101 - Did you chase down Fault E05 error?
из
@teardowns101 depends on the model of your DW. the error code can be a faulty float switch, a faulty temp sensor or a power module failure. What model is your DW?
из
Yes, I did and it said it might be a power module faliure but I don't know why it would be able to turn on and work for a short period of time if the power module was broken
из
Добавить комментарий
1 ответ
Выбранное решение
Unforunately, when an appaliance repair person came (I hoped to simply replace the float switch) he explained that the power module was broken (as the link I posted for error code E05 suggested). Apparently codes E05 and E5 have different meanings:
For anybody else with issues invloving a Bosch Dishwasher
Error code for E5 is for the float switch which can be purchased here: https://www.reliableparts.com/product/in...
Error Code E05 is for the power module which is difficult to replace and is usually very expensive (repair quote was $580 for a $900 dishwasher).
The repair man did restart the system for me (https://howtofixit.net/bosch-dishwasher-...) and then this dishwasher ran for 1 cycle and then subsequently died and I was not able to enter service mode. Likely this is a computer error, but since it will take around a week to get parts (and possibly have to replace other components as well) this dishwasher is going to be replaced...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
teardown-er будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 48
За всё время: 1,140
