Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
No image displayed, some light is present
I am not sure if this makes sense or not. No image is display , but light is present. I am not sure if this is backlight. I have never opened it up.
This or may not be relevant, but this ipad mini 3 hasn't been used in a while.
Is it a possible a reseat of LCD is needed?
Troubleshooting
1.) I held the home button + power while connected to PC. I updated IOS first. The apple logo was never visible.
2.) Repeated same process except did a restore/factory reset while connected to PC. Apple logo was never visible.
*Once done PC / itunes detects it as new device.
Thanks in advance for your help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
The screen issue is not software/iOS related as you have done the troubleshooting to rule that out, you will need to open it up and check if LCD cable is dislodged.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Alf будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 73
