How do I repair the window in the front driver door
How do I repair window in front driver side?
Это хороший вопрос?
Это хороший вопрос?
You may use WD-40 lube spray. I had to pull my window up and down as much as possible! Then I attached the straw that comes with the WD-40.
Then I sprayed the tracks and other moving parts heaver than usual. Meanwhile I kept moving it up and down until it was free.
Later it successfully began to inch it up. Then I pulled it up and down until it was as new!
It is good to apply WD-40 often as a preventative!
Best wishes!
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 25
Hi,
What year is the vehicle?
из jayeff
Also, what kind of repair are you asking about? Please be specific
из brandon k
