Learn about the skills that you might need to work on your device.
How to unplug PCB connectors on amp/receiver
Hi
These are the two connector types I want to unplug. Do I need a special tool? I'm used to motherboards but first time with amp/receiver.
Pics included.
Thanks
Update (04/23/2022)
@oldturkey03 here you can see what I mean
Это хороший вопрос?
Счет 1
6 Комментариев
@jazzier looks like those are just pull connectors. What make and model is your receiver?
из
@oldturkey03 hi thanks for responding. It's a 1988 Marantz amp/receiver ST110 the sound system user manual is identified as TA110/150. I have another older question pending regarding no display on this receiver. So I know you pull the connectors but how do I unlock them before pulling? I tried and they are very delicate and not much space to manœuvre.
из
@jazzier can't see how they are locked but lets see if I have a manual somewhere for this model.
из
@oldturkey03 pretty sure they have a base to clip into. There are little indents on the sides and on the top picture for the smaller connectors you can see a rectangular portion on one of the wider sides that moves loosely. How do I add picture in a comment?
из
@oldturkey03 look at the picture in an answer here at bottom of page. I tagged you.
из
Показать ещё 1 комментарий
Добавить комментарий
1 ответ
Наиболее полезный ответ
pull up on the connectors
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
They have a base.
из
Добавьте свой ответ
Jazzy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 278
