Oil getting out above the coil
Why the oil is getting out above the coil box, and since i started to see the oil the startup sound is reduced.
Dodge challenger srt8 2012 ^manual^.
Это хороший вопрос?
Это хороший вопрос?
Coil box? Ignition coils?
On the hemi head, there is a seal around the coils that is supposed to keep the oil under the valve cover. When that fails, you get oil around the spark plug etc. - real mess.
The fix is to replace the gaskets around the valve cover including the ones for the spark plug tubes. Pretty sure your car has 16 of those. Depending on what is in the way of the valve covers it could be a relatively easy job.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 137
