Toshiba TV display fault
Hello,
I have a Toshiba 49L621U with a display problem.
I have not had any previous issues with the display.
I moved the TV outside to our tent trailer and plugged it into the trailers 110 outlet. The trailer was running on shore power via its attached heavy, grounded extension cord. It powered up and worked properly for three hours or so while my kids watched a movie.
The next day I moved the TV back inside. When I turned it on it functioned normally but within 10 minutes or so the display shut off and the audio continued playing. This pattern of normal function ending in the display turning off but audio remaining is consistent and won't stop.
I have factory reset the TV from the onscreen menu.
I have unplugged the TV from all power sources and let it sit for hours.
I have confirmed that the issue isn't specific to any one input port. The display fails in the same time frame when using the built in Chromecast.
I have examined my power cord for damage.
No luck so far!
Это хороший вопрос?
