Why do I not have control of what my phone is doing
I will be on my phone..doesnt matter wether im playing a game, do a google search or trying to text someone, it will suddenly start switching screens and doing its on thing (ex. I will be playing a game and end up on Google looking at an advertisement)
Это хороший вопрос?
Оценка 4
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Sounds like the digitiser has had damage and is ghost touching. You could open the phone, disconnect the battery then disconnect the reconnect the screen connection ensuring it's seated properly. Then power it on and see if it fixes it. If not you'll need a new screen.
Был ли этот ответ полезен?
Оценка 2
Based on your description we have to assume you install plenty of applications on your device. Its not uncommon for "free" games to show you adds while you play, it is how the game developers make thier money on the game. but for the phone to take you to a google page while texting would imply there is possibly a very aggressive app that can do that kind of thing installed on your phone.
You can manulally review the permissions each app has on your phone by following the steps below - NOTE removing an apps ability to do anything will likely break its function, like stopping google maps from accessing location data, so make sure you understand what an app is meant to be doing before you start changing permissions.
Common sense is key here, if you have an app that is for example a calculator app, it probably doesnt need rights to see your contacts and control call settings.
  1. Open Settings and choose Apps & notifications.
  2. Find and select the app you want to check permissions for.
  3. Tap Permissions.
  4. Now you can see all the app's permissions. To change a specific permission, tap it.
  5. Here you can delete any permissions you aren't comfortable with.
This or just factory resetting your device and slowly re-installing the apps you use until the behaviour resurfaces, then unisntall that app forever.
Adds are gross.
Оценка 1
This sounds like there has been a problem with the digitiser and that it has ghost touching on it. It would be helpful if you opened the phone, disconnected the battery, then disconnected the screen connection, reconnection, ensuring the screen connected properly before closing the phone. I would recommend turning it back on and seeing if it fixes the issue. The screen will need to be replaced if the previous one does not work.
Оценка 0
Добавьте свой ответ
Julie Schrader будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 448
