The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
How to fix stick drift?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
This probably won't help, but it's worth a try. And that's cleaning them, preferably with 90%+ isopropyl alcohol.
If that doesn't help, you will probably need to replace the whole joy-con, I don't really know how it looks in the Quest Controller but I'm 99.9% sure that it's using the same design as everyone else. So you may need to figure out how to get it apart yourself.
The problem is in the design where after some time the surface in the joy-con that the signal goes through is worn off and loses contact.
Hope this helped! :D
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks for the help.
из
Добавьте свой ответ
NR26 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 426
