Fix your 5G Edition Samsung Galaxy S10 smartphone with these replacement part DIY repair guides.
14вопросов Показать все
Charger is overheating on a refurbished device I purchased. Battery?
Charger block for Galaxy S10 5g overheating do I need to replace battery or charger port? I've tried all different chargers and cords including the one that came with the device.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Are you sure it's overheating? The charger brick gets hot when in use because that phone supports fast charging. You can turn off fast charging in settings and see how hot it gets then.
из
Добавить комментарий
2 Ответов
Finger Lakes Fishing how hot is to hot and you did not tell us if your phone charges or what happens when the charger gets to hot. Anyhow since it happens on multiple chargers I suggest that you contact the seller and see what got refurbished. Make sure they are reputable and if so consider exchanging it. After all, refurbished devices should still be functional. If for whatever reason you cannot do this, yes, I would go ahead with a new battery. Also, get a USB ammeter and see what amperage your phone pulls. This could be an indication that there are issue with the charging circuit. In that case a new daughter board should fix this. Something like this video will help you with that.
Был ли этот ответ полезен?
Оценка 0
All lithium battery chargers are current-limited. It seems unlikely to me that the battery would be able to overheat the charger. But of course there are many other current sinks in there. I like oldturkey's charger circuit. Not that it matters much, you'll want a return/exchange in any event.
Оценка 0
Добавьте свой ответ
Finger Lakes Fishing будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 747
