Can this "disconnecting" keyboard be fiexed?
For a little over a year now, My MBP has been having this issue. While in normal use, the keyboard and track pad will become inoperable (When in windows, the sound of a usb device being disconnected occurs). I found out that if I press on the area left of the track pad, the keyboard will reconnect.
I have considered this a minor annoyance up until a few days ago where the the keyboard/trackpad wont work unless I hold on to the aforementioned area. Is this even fixable or should I just sell this MBP for parts and get a new laptop?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
This fault is well known. The little USB controller on the PCB under the trackpad is failing / desoldering. It's the square chip visible when you remove the battery. There are basically three methodes to remedie / solve this:
- cowboy: fold a piece of paper and pich it between battery and chip.
- homebrew: Take a small tip soldering iron and retip all the solder joints ( magnifiere required)
- luxury: replace the topcase.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Alex Satterlund будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 292
