Reset Bios Netbook Asus Eee PC 1015B
How to Reset Bios Netbook Asus Eee PC 1015B?
where I can found original bios (bios first release)?
Это хороший вопрос?
Это хороший вопрос?
To access the BIOS hold down the F2 key at boot. In there you can reset all your options. See if this is the BIOS file you need http://dlcdnet.asus.com/pub/ASUS/EeePC/1... and if that does not work for you download it from here Hope this is what you are looking for. Good Luck.
Был ли этот ответ полезен?
I hold down the F2 Key or F9, but nothing, only show "Enter Password"
Noeorel, actually that is a lot :-) Your BIOS is password protected, henceforth you can not access it unless you have the password. What happens when you press Ctrl+Alt+Del twice when PC starts?
Oldturkey I feel you are doing a good job at helping this person access their BIOS. However, I believe the problem here is that either the system or the hard drive is password protected and that Npeorel would like a work around or the ability to flash the bios to remove the password preventing them from "owning the box". From what I read they have no desire to actually get into or alter the BIOS except to remove the password. Noeorel is what I said true?
+If I could bump you up on this one again, I would for effort. Have you noticed how Noeorel has avoided addressing/answering my comment. I see these kind of questions all the time from the Middle East or the Orient on other forums.
use ''resettler bios`s Software"
Thats Dos Software.
how do a reset it from it sayin on the start screen NTLDR is missing
press clrl+alt+delete to restart but wont restart and its an asus ess pc a need help!
im having the same issue that Noeorel is having. I have an asus eee pc netbook and It keeps beeping and it only shows "enter password" in the middle of the screen. what do I do to make it go away?
selamat siang.. bagaimana cara mereset pssword note book Asus Eee PC seasheall Series agar bisa masuk ke bios.. saya sudah coba beberapa cara tapi tidak berhasil.. terimakasih
selamat siang, bagaimana cara mereset Password di notebook Asus Eee PC seasheall Series, Karena saya tidak bisa masuk ke bios,. beberapa cara sudah saya lakukan tapi hasil nya nihil. tolong dbantu agar saya bisa menginstall ulang notebook asus saya.. terima kasih
no me da el codigo de recuperacion de contrasña
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 16
За всё время: 39,684
10 Комментариев
I never use a password, untill my netbook show "Enter password".....can help me please?
из Noeorel
Have you tried to Ctrl+Alt+Del twice when PC starts? what happens?
из oldturkey03
I had tried Ctrl+Alt+Del twice, but nothing happens, still black screen with center of screen "Enter Password"
из Noeorel
try "Administrator"
из oldturkey03
I have type "administrator" but can not enter bios.
из Noeorel
Показать 5 больше комментариев
