I can’t remove screws from home button
I’m having trouble removing the home button screws, I’ve tried two different screwdrivers and they’re not budging. please help
Это хороший вопрос?
Это хороший вопрос?
Two two screws are just Philips #000. Assuming you're using the correct screwdriver and you haven't stripped the screws, a good way to get a tight screw loosened is to actually tighten it a tiny bit first. This "breaks" the seal that the screw may have with its matching thread, making it much easier to loosen and back ou.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 25
