A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563вопросов Показать все
Broken spacebar key MBP
Hello, I have problem with butterfly keyboard.
My spacebar just broke and I don't know how can i fix that. I brought my laptop to Apple service (I bought it in 2017), and they said, that I need to pay them 1900PLN (445USD) to fix that. What can I do?
Это хороший вопрос?
Оценка 0
1 Комментарий
Where do you live? Country and nearest city maybe we can aim you to an independent repair shop which can fix your system for less.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
Butterfly keyboards are quite fiddly to work on but have you tried
Blowing compressed air under the key
If this isn’t working your best bet is to have a repair shop do it, or if your quite good with small delicate parts you can try and replace the key and clean the switch yourself but this isn’t recommended
Hopefully this answers your question
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Olivier Marszalkowski будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 238
