Why my phone is slow changing
Why my charging taking lot of time
Это хороший вопрос?
Battery could be going bad, you could be using a charger that does not support fast charge. If fast charge is not available in your settings that would be likely.
Был ли этот ответ полезен?
when i have time to reply🤣🤣
The problem can be caused by using cheap cable or adapter, make sure you have right charger(fast charger 15w), if you are using different adapter that is below 15w will charge your phone slow if its above 15w it will damage you battery.
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 48
За всё время: 773
1 Комментарий
Very slow charging problem and very slow working mobile system
из Lavkush Kumar
