A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563вопросов Показать все
Battery Board Cable Question
Does this little cable near the battery board do anything? I got a replacement battery and this cable is a bit different than the one on the original battery and the wire inside is exposed. Just want to be safe and hope it's okay. Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It looks like you've pulled the battery board fully off the battery assembly. The cable end is attached to the battery where a thermal sensor sits with a second on the end of the thin cable.
Loss of the thermal sensor will prevent the battery from working properly.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Mac будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 30
