Craftsmen 247203734 of both belt drive idler pulleys & b
Sears diagram not good need belt drive idler pulleys and both brackets and spacers bolts etc. and how they attached to floor pan. This model is diffrent than the other 50 models MTD has produced. . IM HAVING PROBLEMS WITH THE PULLEY THAT GOES THROUGH THE FLOOR PAN JAMIMNG UP. ANY HELP BE APPRECIATED
Это хороший вопрос?
Оценка
0
Fastcar81 sounds like you are referring to the PTO pulley. It might help if you can take some good pictures and post those with your QUESTION. That way we can see what you see. Adding images to an existing question Just to verify this is the wrong diagram?
из oldturkey03
