I love these marketing ads! Trying to trick you into thinking you can get more than what is physically possible.
- So how many quarts of milk will fit into a gallon jug? Sorry only four and no more!
This same logic holds true with batteries on the most part. The physical size of the battery limits what can fit for the anode/cathode and the electrolytic which is the active part of the battery. While Lithium Ion chemistry has improved from the early days, it hasn't changed by leaps and bounds since 2005 and 2015 batteries Apple used where the best that could be bought.
Now to mess you up! Each battery when tested can be within a sizable tolerance window. Culling the better batteries and selling them as the premium (Apple gets these batts) is as best as they can do but the differences is not that much from what is the expected norm. You could also get a bad battery one at the very bottom of the tolerance window! So you do need to make sure the seller stands behind what they sell.
Lastly, Doping of the chemistry can improve the discharge so it can appear to be a better battery! But the lifespan of this battery is dramatically lowered! So it costs you more in the long haul! It can also allow the battery to cook when charging! Which in turn can cause the device to go up in flames!
Don't fall for these pushers they are selling you just a labeled standard battery which is meaningless, paying for nothing special or if its a doped battery then you risk your device.
I doubt 4500mAh is correct more likely 2750 mAh, If its correct then its a doped battery! The key is physical size of the battery which can press on the display damaging it as well as the voltage.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
