Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
My humidifier heater isn't working.
My Airsense 10 is about 2 years old. My humidifier heater quit. I pulled the cover and checked the fuse and it is good. I don't have a schematic to check the test points. Could you give me some info on the heater?
Thanks!
Это хороший вопрос?
Счет 1
1 Комментарий
Yes this is the fuse under the heater plate. I unclipped it to test its continuity.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Bg Higg by checked the fuse I assume your are referring to the one under the heater unit like shown on here Data on the heater is not freely available so I would go ahead and replace the heater on use a bench power supply to see if that could run the heater.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
This is unhelpful. Where can we get a new heating element?
из
Добавьте свой ответ
Bg Higg буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 670
