start up problems
I have similar start up problems with my white 24" imac (EMC 2111). My observation is following: the lowest of the 4 green diagnostic leds is burning, then more leds are lit for a moment but without success. Also the fan (close to bottom left speaker box) rotates for a moment. This is automatically repeated a few times, until the machine gives up. Now, all leds are off.
I can repeat this cycle of trial and error by disconnecting the power cable for 5 sec or so, and then reconnect.
In the last few days, most of the time I had no success, but a few times I could get the machine back from death by just trying, although I have no idea if I will succeed next time. The machine never broke while I was working - it usually happened in the morning when getting the Mac awake. When I am sure that it is indeed the power supply, I will replace it.
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Выбранное решение
The diagnostic LEDs to the right of the RAM slots (this may be covered by a piece of black electrical tape).
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
If no lights are coming on you need to replace your power supply. A trickle charge is sent from the power supply to the first LED. If the first LED is not lit the power supply is not working. If the power supply is weak and can't sustain the system, the LED may be lit but unusually goes out with attempts to power on the machine.
Power up is the hardest thing on any of the components in a computer - RAM, CPU, etc... are pushed to their max and pulling more than operational current. The symptoms you are giving are of a weak, near dead power supply.
It is going to give off all the proper voltages on the pin out, as it is weak - not dead. The only thing it can't do is pass a current load draw test. You could do that by installing it in another iMac to see if it gives off the same symptoms or you could replace the PSU.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Norbert Vischer будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 985
