I need to replace the lighting cable will the iPhone 13 pros work
In search of a lighting cable port for the pro max but all you seel is the one for the pro is that compatible with the pro max
Это хороший вопрос?
Это хороший вопрос?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 119
6 Комментариев
are you in the states or europe
из daniel
@tech_ni in the states
из Andre Glass-Johnson
@Andre Glass-Johnson sorry thought it was a port you needed, should be the same cable
из daniel
@tech_ni it is the port my apologies the entire charging port on the pro max is acting up if i can use the one they sell for the peo itd be great
@Andre Glass-Johnson sorry but it wouldnt work, mobilesentrix have the pro max ports. here is a link to the pro max parts. go for 1 labelled pull so that you dont have issues. https://www.mobilesentrix.com/replacemen...
из daniel
Показать 1 больше комментариев
