Viewfinder not working, LCD is okay. How to repair?
My Sony DSC-H50's viewfinder does not illuminate when I switch from LCD to viewfinder mode. All other functions work, including the external LCD display. Does anyone know of a repair guide or video? My searches have turned up nothing.
EDIT: After posting this yesterday I did see the viewfinder flash (illuminate) briefly several times, but not in any reproducible way and not when I tried to switch to viewfinder mode. Seems most likely it is a loose connector.
EDIT2: I have attached the Sony repair manual (to the camera info page), but it doesn't really list steps, so I'm hesitant to dive in.
Это хороший вопрос?
6 Комментариев
Have you tried disconnecting any unnecessary modules and testing ? I have encountered a similar issue on some canon cameras when the flash module was shorted
из How It's Fixed
Thanks, HIF. This camera has no accessories/modules attached.
из Hypercaff
@hypercaff hey, I think you misunderstood me. I’m taking about the built in flash module which is present in this model.
из How It's Fixed
You're right, I did misunderstand you. The flash module works fine. I haven't disconnected it because I haven't yet figured the right way to disassemble the camera.
из Hypercaff
@hypercaff this service manual should help.
Good luck !
https://www.manualslib.com/manual/125436...
из How It's Fixed
Показать ещё 1 комментарий
