Will not boot. replaced power supply, still only 1 diagnostic light
Replaced power supply and memory, but iMac 20 still won't boot up. Only 1 diagnostic light
Это хороший вопрос?
Это хороший вопрос?
This sounds more like your drive has failed if you are seeing the screen and an folder icon is shown with a blinking question mark.
Taking the display off will impact the onboard LED's as the screen won't vibe wired in so while LED #1 is lit it only tells us power is getting to the logic board, as you also altered the RAM we can't rule out if the RAM is good of fully inserted. I would go back to the original RAM to see if things are working.
Был ли этот ответ полезен?
No mattem what I have tried, the computer will not boot up, absolutel no activity, onthe than the one diagnostic led. I am considering replacing the logic board but would lie an expert's opinion before I do that.
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 15
За всё время: 59
Can you give us a bit more here. What happened to the system? Did you get a power outage or lighting strike nearby?
из Dan
It was a slow process of not booting up. Held the on button for a few seconds, and then would boot normally. Finally reached the poin it would not boot at all.
из Wallace Hamilton
