My phone is not turning on
Before 1 month ago my realme c1 phone was suddenly turned off then I go to for repair they changed the folder and it was working after 15 days it happened again and my phone has been turned off while charging time.
Since then my phone is still not on.
Can you help me।
Это хороший вопрос?
Счет 7
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Try to press and hold the power button for few minutes and repeat this process and check if its works.
Был ли этот ответ полезен?
Счет 2
If there is lint in the charge port, the cable can't seat properly and this can prevent it from charging at all. VERY CAREFULLY use a pin or needle to check that the phone's charge port is clean.
Счет 1
Добавьте свой ответ
THIS IS PAVAN KASHYAP буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 41
За всё время: 1,418
