The Ryobi RS290G is a powerful Orbit Sander that boasts 12,500 rotations per minute. With an Ergonomic Grip to stabilize, and a dust bag to collect debris it is the perfect all-round sander.
Why is my Ryobi making a weird noise?
My Ryobi sander started making a strange noise and is not sanding proper. I made sure there were no loose screws, cleaned it and then let it sit for a few hours to cool down as I had been sanding on and off for several hours. Unfortunately none of these seemed to help. What could be causing this and is it fixable ?
Это хороший вопрос?
Счет 0
2 Комментариев
What sander is it? Belt, orbital, detail sander?
из
It is a Ryobi corded orbital sander
из
Добавить комментарий
1 ответ
Выбранное решение
Possibly a bearing going, either to or bottom. I’d split it in two and remove the motor and check them. Could be wear on the base where the bearing sits.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
bhowse@live.ca буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 799
