The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
82вопросов Показать все
MY washer won't turn on.
I out a small load of clothes in the washer, started it and with 35 minutes left it just turned off and wont power back on. I have tried different outlets and still no luck. power runs to it when plugged in, but still won't turn on. Any ideas why?
Это хороший вопрос?
Оценка 0
4 Комментариев
Hi,
What is the full model number of the washer?
There are 5 different model 765BW0 to W4 and they're not all exactly the same as far as parts go. Just in case it is a faulty control board for example
из
@jayeff
i have a maytag MVW7232HW0 serial # CX14 70785
из
Mine is a Kenmore top loading, the outlet has power but nothing. It was in the middle of a load when it happened.
из
@Leo Potter Sr.
What is the model number of the washer?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Not sure what you meant when you said "...power runs to it when plugged in, but still won't turn on."
Did you mean that there is an indication that the washer has power i.e. lights on etc or that there is no indication of power at all i.e. appears dead.
If it appears to be totally dead there is a line filter part #12 that the power goes through from the cord before it gets to the control board that may be faulty.
The supplier is an example only to show location of the part. Search online for W11033573 to get results for suppliers that suit you best. To prove it is faulty or not use a DMM (digital multimeter) and check if there is 120V AC on the control board connector J1 pins 1 & 2. Be safety aware as it is AC voltage you're testing for.
If there is power on the control board try running the diagnostics as described in the tech sheet and check if it does work and what the error codes, if any, show.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
the washer receives power, but the screen stays off and makes no sound. i have tested both the outlet and the washer and both have 120V. when it gets plugged in it just stays off.
из
@deadslayer6
Did you try getting into the diagnostics as suggested, you didn't say?
Check if there is 12V DC and 5V DC on mainboard connector J14 1 & 2 respectively and 12V on J9 pin 1. Not sure if the voltages are there all the time but suspect that they should be. This is only to prove that there is DC voltage on the mainboard.
If you can't get into the diagnostics and even if the voltages are there then it's looking like a mainboard issue.
из
Добавьте свой ответ
deadslayer6 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 769
