Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64вопросов Показать все
doesn't seem to detect my airport extreme wireless card
I brought a airport extreme wireless card that stated the card would work perfectly with the iBook g3 model but that seems to be far from the truth so far do you have any ideals of what my next steps should be thank you in advance for your time
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Выбранное решение
Hi odell, welcome to iFixit Answers.
The airport extreme wireless card will not work in your iBook G3 clamshell. You need to buy the first generation Apple wireless card. The airport extreme wireless card will only work in iBooks G4/PowerBooks G4 and G4 towers so return the card for a refund or maybe your seller has the first generation card if so ask for a swap..
Here's the card you need:
http://aftertheMac.com/wireless/airport_...
Here's probably the card you received:
http://orangeyemen.com/shop/images/orang...
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
I missed that. Way to go. +vote
из
Under the Apple icon in the upper left hand corner, Go to About this Mac. This is the system profiler. Hit the More info button. In the under "Network" go to the Airport Card. See if the computer can see the card.. Did you remember to plug in the connector to the card?
Оценка 0
Lemerise is correct. Airport Extreme card won't work in clamshells.
Оценка 0
Добавьте свой ответ
odell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,323
