Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
3DS no power, no charge!
Hi all, I really need some help with a broken 3DS. I bought it on eBay as broken/parts but it seems to have an issue I have never seen before.
So when it arrived it doesn’t power on at all when you press the power button nothing happens no orange light no blue light nothing at all. I opened up the 3DS to have a look to see if there was any very obvious issues and there didn’t seem to be corrosion, broken pieces and water marks are intact.
So I’ve purchased a new battery, new charger and also a set of ribbon cables for the right button because I broke it opening. I’ve confirmed the voltage of the battery is fine and the charger also works for my other console. The ribbon cable replaced really easily but I don’t believe that would have any effect but it’s still not working?
I plug it into the charger not nothing happens on the DS, no lights, nothing! I’ve left it charging for an hour and again nothing happens! I’ve tried multiple batteries and cables. I just don’t know what else to check or look for?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Did the seller say the reason it was being sold for parts? If not it could be the motherboard it may be fried. Also check for any lose components on the motherboard that could also be a reason.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
No, seller just said ‘not working but could be easy fix’. They got it in a job lot.
Motherboard fried is obviously possible but wouldn’t there be an physical sign? There must a fix?
Im just not sure what parts to test? Fuses?
из
Could be an issue with the power delivery. Try looking to see if the charging port is damaged or broken, and try replacing it.
Оценка 0
Добавьте свой ответ
Daniel Wilkinson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 306
