Hello, I have made a 30 pin connecter cable for my iphone 4 since i dont have any, and the cable i did have was broken. I tried resoldering it to a USB cable i cut off, and when I plug it in to the phone, it freaks out and wont restart until I unplug it. Any help?
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
A few years ago I bought a supply of 30 pin cables so I'd have them on hand for when I worked on old tech like the ipods and iphone 4s I have hanging around, so I've still got several lying around.
I pulled one out and checked the pinout between the 30 pin end and the USB end. Here's what I came up with.
Looking at the USB cable on end, from left to right the pins are:
GND
Data +
Data -
+5V
These map to the 30 pin connector as follows (numbered pins 1 - 30 from left to right)
Pin 15 GND
Pin 16 GND
Pin 23 +5V
Pin 25 Data -
Pin 27 Data +
Note that on the 30 pin connector, only those pins had an actual wire, with the exception of pin 1. However, no matter how much probing I did, I couldn't find any continuity between pin 1 and anything else. The shield in the USB is also a no connect; it doesn't connect with the shield on the 30 pin end, or anywhere else for that matter.
I found a pinout for the 30 pin connector that matches up with my findings.
