The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
How to repair intake manifold runner control
1999 Ford F-150 code p1518 how to repair ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
@ecjones3rd surely you already checked to see what your error code P1518 covers
Faulty Intake Manifold Runner Control (IMRC) actuator
Intake Manifold Runner Control actuator harness is open or shorted
Intake Manifold Runner Control actuator circuit poor electrical connection
Faulty Powertrain Control Module (PCM)
So you do want to start by checking the connections, wiring and clean any potential corrosion etc from the connectors. After that you want to check places like this and see if that will help you further. You have to investigate a bit on those parts since the error code is not telling you to specifically change/repair one part.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Ed jones будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 504
