Acer 11 C731 replaced charger port wire and still won't charge, help
Replaced Charger port on Acer 11 c731 and charger light won't go on or charge. Is there anything else I can do or charge this chromebook a different way?
Это хороший вопрос?
Это хороший вопрос?
In my experience, if replacing your DC-In Jack did not resolve your issues, there is most likely an issue with your machines motherboard, or battery.
In most cases, it may not be worth putting a lot more effort into fixing this issue, as the motherboard generally outweighs the cost of a new machine entirely.
Был ли этот ответ полезен?
Hi,
If you know how to use a DMM and how to read schematics then maybe consider buying them. Here's a supplier
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 116
4 Комментариев
did you try a different charger ?
из daniel
Yes multiple chargers and even tried multiple new ports
из Stephanie Adamietz
@Stephanie Adamietz then its more than likely an issue with the motherboard
из daniel
Thank you we decided to just replace these and keep them for parts.
