How do I un mod a galaxy Tab A
So a year ago I modded my tab and now I want to un mod it
I feel like you can't un mod it so I wanted to check here
Это хороший вопрос?
Это хороший вопрос?
Here is how you do it:
Note, there is one important caveat. If Samsung devices detect a non-Samsung bootloader, they will trip the Knox WARRANTY VOID bit and Knox-related features will no longer work, such as Knox Workspace, Samsung Pay, and Secure Folder. This is irreversible because it blows an eFuse inside the SoC. The only way to fix this is to replace the motherboard. Check the status of the warranty bit in the tablet's download mode. If you don't care about Knox then you can use it as normal, if it is 0 then it is still intact and you didn't actually install a custom bootloader (and therefore a custom ROM).
Also please note that I am not responsible for you bricking your device.
Был ли этот ответ полезен?
Thank you so much! I've been looking for information how to install firmware for sumsung wifi only devices, as It has no CP file I was hesitating to install another version, as some people say that It can brick your device. But now I'm clear. Thank you again!
Hi
If it’s jailbroken you should just be able to reinstall the OS and it should be un-modded
If it’s modded in terms of hardware you just need to reverse whatever you originally did to it
Hopefully this helps
Any questions please ask
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 20
За всё время: 173
