Can an Additional SSD be installed?
Unit has blade ssd already installed. Is it possible to add an additional sata ssd?
Это хороший вопрос?
Это хороший вопрос?
Here's what you'll need:
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
Here's how to do it:
iMac Intel 21.5" Retina 4K Display (2017) Hard Drive Replacement
Был ли этот ответ полезен?
@bigmac98 & @mayer You'll also need the cushions and SATA cable as the blade SSD models won't have these.
@danj If it doesn't already have a drive, will it also need the thermal sensor?
@mayer - The 2.5" dive systems don't need the thermal sensor as long as it supports the newer S.M.A.R.T. Services. All current drives are AOK!
Thanks for the help Mayer! Much appreciated.
@bigmac98 - Don't forget to vote and accept the answer if you're set!
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 46
