Repair and troubleshooting help for the HP Elitebook 840 G2, a 14" laptop computer from HP.
Bugging when plugin charger
Hello guys,
When I plug the charger the laptop is bugging.
I can't do anything. Everything is slow, even the START menu cant be launch.
But when I remove the charger Everything works fine. The problem is also I cant see the battery icon in taskbar and it going off without any notification of battery dischatging.
Please help
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Try to completely discharge your computer: remove the battery, hold down the power button for 10 seconds, and reinsert the battery.
If that doesn't work, run HP's power adapter troubleshooting tool at https://support.hp.com/id-en/help/diagno...
Third, try a factory data reset to remove any faulty drivers or software that could be causing the glitches.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Gaspard Tryphon будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 111
