Screen stopped working after battery replacement
So I just replaced the battery in my Samsung Galaxy S10. After installing the new battery and the charging coil, I turned the phone on to confirm it still worked. Everything looked good, I unlocked the phone, made sure the touchscreen worked fine, and turned it back off. Then I glued the backplate back on.
I set the phone down with books for an hour to dry like the instructions said, then when I go to turn it on , the screen never turns on. It buzzes, and I get notifications, but the screen is just completely black.
Any ideas?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Hopefully the cable going to the LCD from the board became disconnected which should be a quick fix. If that is not the case, it is possible that the OLED panel of the display was damaged which would give the symptom of the phone powering on vibrating/making sounds but not showing anything on the display.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Matthew будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 37
За всё время: 240
