The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428вопросов Показать все
Boots into error menu and offline update fails
I got this xbox one s from my friend in this state. It powers on into the startup error menu with E203 . I then proceed to offline update it and it gives me E101 immediately after starting. I haven't seen any solutions to this anywhere else so I thought I should ask it here.
Это хороший вопрос?
Оценка 0
2 Комментариев
Good afternoon from Australia,
Have you tried googling this? If not then maybe try looking at other places.
Based on what I have seen, replacing the hard drive might be a good idea as it could be a faulty hard drive (You never know)
из
Thanks I'll try it
из
Добавить комментарий
2 Ответов
Выбранное решение
It turns out the hard drive was bad. I replaced it, performed the usb update, and it worked. Thanks for the help!
Был ли этот ответ полезен?
Оценка 0
Hi,
There are a few things you could try
  1. resetting the Xbox to factory defaults
  2. downloading the update on a USB and installing offline https://support.xbox.com/en-GB/help/hard...
  3. Replace the hard drive
If I were you, I would try in that order and hopefully 1 should get you to the bottom of it
Оценка 0
Добавьте свой ответ
Wyatt будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 416
