Пульт дистанционного управления DJI RC-N1 (также известный как RC231), модель RC231. Совместим с дронами DJI: Mini 3 Pro, Mini 2, Mini 2 SE, Mavic Air 2, Air 2S, Mavic 3, Mavic 3 Cine.
My drone controller went off while in flight and still not turning on
My deone controller went off while in flight and still not turning on, I tried changing but no indication.
Это хороший вопрос?
Счет 3
3 Комментариев:
Firstly, I hope you didn't lose your drone. Those are expensive machines!
Does it have a removable battery? If so, do you normally charge the battery while it is in the remote or do you have to connect it externally? IS there any bulging of the battery pack?
из Поделиться
Yes luckily the drone landed safely. No it's a inbuilt battery. It's a dji mini 2 drone
из Поделиться
I have the same problem the controller won't charge and won't turn on and there are no LED Lamps on
из Поделиться
Добавить комментарий
1 ответ
I have this same drone, but have never had that issue, if you have knowledge about repairing electronics and feel comfortable, i would try opening it up and checking the battery connection wires, that may have gotten unplugged somehow. If that doesnt work i would recommend either a battery replacement (i don't know if that is possible to do DIY for this controller) or i would send it back to DJI and see if they can repair it. A sudden loss of power may not be a battery related issue as batteries dont tend to do that if they are connected properly, so it may also be a problem with some other part of the controller or power distribution circuitry inside.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Got the exact same problem yesterday. I'm wondering how to fix this now.
из Поделиться
Добавьте свой ответ
Mack Fernandes буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 36
За все время: 1,235
