Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
replace PATA optical drive with an SSD drive
last night I had a crazy idea!
would it be possible to replace optical drive (PATA)
with an SSD drive?
the only problem is the PATA connection instead of SATA, I don't know if there is an adapter or PATA SSDs
edit: I found this:
[ http://eshop.macsales.com/item/OWC/SSDMX...|OWC Mercury EXTREME Pro Legacy Edition 9.5mm for IDE/ATA desktop systems]
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
Here's what you need to put in a SATA hard drive in your PATA optical bay slot: [связанный продукт отсутствует или отключен: IF107-078]
Был ли этот ответ полезен?
Счет 5
4 Комментариев:
from the notes on the link: This enclosure does not work with ATA drives or hard drives thicker than 9.5 mm.
plus: Compatibility >> MacBooks
из
again on the notes: This enclosure does not work with ATA drives or drives taller than 9.5mm.
which I don't understand why! PATA drives have different sizes?
из
ok finally I can answer to my own question!
this a Caddy for this type of iMac. It converts Sata (internal) to Pata (external) you can use any data connection 2,5" drive (ssd or hdd).
here is the site selling it:
http://www.newmodeus.com/shop/index.php?...
Счет 1
Добавьте свой ответ
joleisa буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 3,970
