Игровой контроллер в виде барабанной установки для игры The Beatles Rock Band на консоли Wii, выпущенной компанией Harmonix в 2009 году. Это руководство по ремонту поможет вам устранить неисправности и/или заменить определенные детали барабанной установки. Идентифицируется по номеру модели NWDMS3.
Anyone know the name of this part
My drumkit the bandhero model and there's 2 purple audio inputs for the bass drum but mine are broken does anyone know how to find the name to but the replacement part or does anyone know a fix looks like it's got 3 pins
Update (09/21/2022)
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
CJ Allison I figure you are looking at the 3.5mm purple connectors. Some places list them as 3.5mm audio jack others strictly as 3.5 mm phone connectors. Not sure where to get the ones that are originally intended for your circuit board but you can replace those with other ones. The main issue is going to be dimensions and location of the contacts. Get some calipers are equivalent and measure the connector. The go check with places like this. There might be some that will come close to the size you will need but it should be doable.
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Thanks I'll have a hunt and try a similar looking one
из
Can't seem to find the same pin layout anywhere think it's safe to say I have no hope of fixing it
из
Can you post the dimensions of the connector on here. That way we can try and help you with that. I hate for you to have to give up on this. Do you have some "wiggle room " of where that board sits? Can it tolerated slightly different dimensions?
из
This company would probably be able to identify and sell the parts you need:
https://www.sweetwater.com/c1193--Drum_R...
Счет 1
1 Комментарий:
Thank u muchly I'll take a look
из
Добавьте свой ответ
Cj Allison буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 20
За всё время: 483
