keyboard not working caps lock led on
Hi, on my razer blade 14 2016 laptop keyboard stopped working, capslock led is constantly on, fans are running at full speed
Это хороший вопрос?
Это хороший вопрос?
If for some reason, you press the Caps Lock and the light doesn't turn off, this might be why. Check if pressing the SHIFT key would turn off the CAPS lock. If that does the trick, then the reason is your Windows setting had the CAPS lock only turned off by pressing a SHIFT key selected
Hope this helps
Был ли этот ответ полезен?
Hey adam, im having the exact same problem, have you found a solution yet?
Hi, the problem is in the keyboard controller module board, just replace it with the same working, or replace palmrest assembly
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 187
